TwinTurbo.NET: Nissan 300ZX forum - ? Agreed, the belt should stay relatively lined up, even
Tanley
on June 19, 2015 at 3:25 PM
If belt wants to move forward on that pully will >>
posted by ZUL8TR
on June 19, 2015 at 03:00 PM
without the sprocket washer installed. That looks slightly on the excessive side. Check all of your pulleys and tensioner, make sure everything is tight and nothing is bent or damaged.
New timing belt installed
z32z
11:00:27 06/19/15
Re: New timing belt installed
z32z
11:03:08 06/19/15
You are missing some parts that might help. They are
ZTicket(Dallas)
12:18:11 06/19/15
I have them and thought that may be the reason.
z32z
12:31:43 06/19/15
That should line it up. (n/m)
ttz'in (norcal)
13:12:56 06/19/15
ZUL8TR
15:00:31 06/19/15
? Agreed, the belt should stay relatively lined up, even -
Tanley
15:25:57 06/19/15
Thanks for all the suggestions. I will double check everythi (n/m)
z32z
22:31:53 06/19/15
